This Wall Mounted Flower Planter Set is designed to bring a simple, elegant, and functional touch to your indoor or outdoor space.
The set includes three different planter sizes, from small to large, so you can create your own custom wall garden layout. You can mount them individually or arrange them one above the other to create a beautiful vertical flower display.
Each planter has a clean rounded shape with a slightly angled opening, making it easy to place small plants, flowers, herbs, or decorative greenery inside. The design includes a mounting hole at the back/top for easy wall installation using a screw.
There is also a drainage hole at the bottom, allowing excess water to drain out and helping keep plants healthier.
Included Models
- Small wall planter
- Medium wall planter
- Large wall planter
- 3D printable wall-mounted planter set
- Three different sizes included
- Designed for flowers, herbs, small plants, or decorative greenery
- Can be mounted one above the other
- Great for vertical garden setups
- Screw mounting hole included
- Drainage hole at the bottom
- Clean modern design
- Suitable for indoor and outdoor decoration
- Easy to print and customize in different colors
Recommended Use
Perfect for:
- Garden walls
- Wooden fences
- Balconies
- Patios
- Terraces
- Indoor plant walls
- Herb gardens
- Small flowers
- Decorative plants
- Vertical garden displays
Printing Tips
For outdoor use, I recommend printing with PETG, ASA, or ABS for better resistance to heat, sunlight, and weather.
PLA can also be used for indoor use or shaded outdoor areas.
Suggested settings:
Layer height: 0.20 mm
Walls: 3–4
Infill: 15–25%
Material: PETG / ASA / ABS / PLA+
Supports: Not required or minimal depending on orientation
For better waterproofing, increase wall count and consider using a slightly higher flow rate or post-processing the inside surface.
Installation Notes
Use a screw suitable for your wall, fence, or wooden panel.
The planters can be installed separately or stacked vertically to create a decorative wall garden.
Make sure the planter is securely fixed before adding soil and plants.
Drainage
Each planter includes a bottom drainage hole to allow excess water to escape.
For indoor use, place something underneath or use a small liner to avoid water dripping onto furniture or floors.
Safety Note
Do not overload the planter. Strength depends on the material, wall thickness, infill, print quality, and mounting surface.
