2026-09-07 10:14:52
288
Wall mount Easy Snap
@MoGoARt_4815258
🔒 Wall Mount EASY Snap Locker
A clean, fast-mount snap-lock system designed for organizing tools, accessories, cables, lightweight gear, and workshop essentials on vertical surfaces. 🛠️
This modular wall mount uses a simple push-and-lock mechanism that securely snaps into place while still being easy to remove when needed. The design is compact, strong, and optimized for reliable 3D printing with minimal supports. 🚀
✨ Features
  • 🔐 Quick snap-lock mounting system
  • 📏 Multiple size options included:
  • Small
  • Medium
  • Large
  • 👌 Easy one-hand attach/remove
  • 🧩 Clean low-profile modular design
  • 🖨️ Print-friendly geometry
  • 🧱 Strong and reliable fit
  • 🛠️ Great for workshop walls, pegboards, desks, and storage setups
📦 Included Files
  • Wall Mount Small
  • Wall Mount Medium
  • Wall Mount Large
  • Interlock Small
  • Interlock Medium
  • Interlock Large
⚙️ Print Settings
  • 🖨️ Layer Height: 0.2 mm
  • 🧱 Walls: 3–4
  • 🟠 Infill: 20–40%
  • 🧵 Material: PLA / PETG / ABS
  • 🚫 Supports: Not required
  • 📐 Orientation: Print flat on the build plate
🧰 Recommended Use
Perfect for:
  • 🔧 Tool organization
  • 🔌 Cable management
  • 📦 Small accessories
  • 🧩 Modular storage systems
  • 🏠 DIY workspace setups
🔩 Assembly
  1. Attach the wall base using screws or adhesive.
  2. Push the interlock piece into the mount.
  3. 🔄 Twist/snap into position until locked.
📌 Notes
  • 💪 bit flexible is recommended for stronger long-term use.
  • ⚖️ Increase infill for heavier loads.
  • 🎯 Designed with tight tolerances for a secure fit.
wall mount
wall snaps
wallmount
