2026-10-25 00:23:17
139
17
Wall-Mounted Silicone Tube Holder
@ArgiCZ_2798409
Design Concept
A practical wall-mounted holder for silicone, sealant, adhesive, and other standard caulking cartridges. The modular range includes four versions, from a compact single-cartridge holder to a larger holder for up to four tubes.
Use
Keep your most frequently used cartridges neatly organized and easily accessible in your workshop, garage, or work area. The integrated lower cup provides a convenient place for the cartridge base, while the upper support keeps the tube securely in position.
Printing Suggestions
Material: PLA for general indoor use; PETG for improved durability and heat resistance
Print orientation: Lay the flat back plate on the build plate
Supports: yes
Infill: 20–30% recommended
Perimeters: 2 or more for a sturdy construction
Assembly Instructions
Mount the holder to a suitable wall or workshop panel using screws through the designated mounting holes. Choose suitable screws and wall plugs for your mounting surface. Insert the cartridges nozzle-up for convenient storage.
silicone
tube
sealant
adhesive
cartrige
holder
wallmount
workshop
garage
organizer
storage
useful
practical
handy
DIY
tool
tools
mount
caulking
utility
