Craft custom waterproof * junction boxes to your exact specifications with this versatile Fusion 360 parametric model.
This new 3D model has the following advantages over the previous version:
- External screws: Water cannot pass through the screws thanks to their external placement.
- Self-printable gasket: The gasket can be printed independently (TPU or other soft filaments are recommended).
- Increased number of screws: A higher number of screws ensures a more resistant seal.
- 🆕 External holes for screwing the box to a wall
Customize every dimension:
- Height
- Width
- Depth
- Screw sizes
- Side hole size
- Dimensional parameters of the gasket
- and more (every field is documented)!
Download now and start creating the perfect junction boxes for your needs!
* Clearly, this box does not have any safety certification. If you want to improve its water resistance, I recommend brushing resin on the box or filling it with electrical insulating gel. Also, I recommend using a high-temperature resistant filament.
*** Changelog ***
UPDATE 8 Jun 2024
- External holes were added to screw the box to a wall
UPDATE 9 May 2024
- Changes have been made to the Fusion source code to improve component management
- Significant changes have been made to the lid, making it more robust and providing more space for screws
Waterproof Junction Box v1
