2025-10-27 04:34:46
8.1k
788
XXL Size Moon Lamp 320mm
@maxim_4198081
This is an extra large moon lamp with a beautiful wavy base, it takes advantage of printer that have a bed 320mm or larger. Two versions available one uses the Bambu LED Kit 001 light, and a second one uses a GU10 bulb for a brighter moon. First photo shows the much larger size in comparison to my 250mm size moon lamp.
The LED Kit 001 version works with both Bambu and aftermarket (aliexpress) kits that have the larger power switch. The GU10 base is to be printed without supports, there is a sacrificial layer you need to break through after printing. The bulb base is a bit loose locking into the moon but you can add a drop of glue if you move the lamp frequently.
Bill of materials for GU10 Version:
GU10 Sockets: https://www.amazon.com/DiCUNO-Resistant-Maximum-Connector-Packages/dp/B07GVB2P2N/
LED bulb: https://www.amazon.com/Euri-Lighting-EP16-7W5020eG-2-Dimmable-Equiv/dp/B09PB1CG3L/
Lamp cord: https://www.amazon.com/RTNLIT-Button-Polarized-Stripped-Replacement/dp/B0C7BZ65S2/
Click here to check out my original bright moon lamp in 250mm size.
Click here for all my other models!
moon
lamp
led
lithophane
decor
gu10
nasa
astronomy
modern
atmosphere
bedroom
led kit
bambu
lampshade
mood
lighting
Maxim3D
LARGE+BRIGHT Moon Lamp Modern Wavy Base 250mm
