2024-04-25 01:52:40
4.6k
492
Yoshi Keychain and Magnet Pack
@Powerpillprints_2496744
This pack has been all set up for super simple and easy printing with the AMS or AMS lite!
All the models are set to 4 Colours! Just load your filament, slice and go!
Most keychains take between 45 minutes to 1.5h to print!
This Yoshi Keychain & Magnet pack includes the following Characters:
Yoshi Magnet & Keychain, Yoshi Cookie, Baby Yoshi Hatching, Happy Yoshi Keychain, Yoshi Head, Yoshi Icon, Baby Yoshi, Pixel art Yoshi Head, Yoshi's Egg, Yoshi eating Apple, Chibi Yoshi, Yoshi Standing, Yoshi Excited, Yoshi Tongue, and various colour options!
I have this set to use the 0.4mm nozzle with a .28mm layer height. This prints three layers of colour so the colours turn out nice and saturated and minimize waste. After the colour, there's one solid black layer, three layers of infill, and four final solid layers for the back for strength with the back pattern set to Hilbert Curve for a nice texture. There is a small hole in each model which is just large enough to fit a 1mm keychain jump ring. If you find it too small, you can modify the size of the “Keychain hole” object in BambuStudio to make it a little larger, or take a small drill bit and drill the final keychain to make it a little bigger!
I purchased my keychain set from Amazon if you'd like to get something similar! The 8mm x 2mm magnets I used can be bought on Amazon as well!
I made some changes to the first layer and first layer infill speeds, reducing them both by about half. This increases the print time for the first layer, but increases the bed adhesion and print quality a bit. If you find that the first layer is printing too slow for your liking, feel free to reset them both back to default settings in the speed tab.
Adding the magnets is easy! Buy some 8x2mm magnets from Amazon, along with some glue (I'm using Gorilla Glue Gel). Drop a small amount of the glue into the holes, and insert the magnets ensuring they're facing the same direction so you don't have a polarity flip between the two :D
Want to remove the keychain ring or hole? No problem! Each keychain has a “Keychain hole” or “Keychain Outer Ring/Keychain Inner Hole” object on each plate. Just select them, delete it, and re-slice! Same thing with the Magnet hole! Just delete that objects if you don't want them there.
Want to scale these up really large to make some wall art? Just delete the “Keychain hole” or “Magnet Hole” object, then scale the X and Y axis to fit your print bed. Keep the Z-Scale back to 3.08mm so you're not printing extra layers though!
There's lots of different colour Yoshi's out there! I didn't want to assume anyone would always want the green one, so i've included a plate at the end that has 8 other colour options. If you want a blue yoshi, just select the green part of the model, and replace with one of the colours in the filament section.
If you notice any settings that could be changed or improved, please let me know! I'd love to make any adjustments necessary so they all print great! If there's any other packs or characters you want to see, leave a comment!
Like this pack? Check out my other Pokemon keychain packs here:
Yoshi
Egg
Nintendo
Super Nintendo
Nintendo Switch
Green
Keychain
Magnet
baby
Cute
Retro
Video Game
Gaming
Gamer
pixel art
cute
japanese
dinosaur
dragon
pokemon
