2026-04-23 17:49:31
48.7k
7k
Z-Axis Lube Applicator - for Kobra X
@PamBigboy_4565857
Tired of getting your hands covered in grease during printer maintenance? Regularly lubricating your Z-axis lead screw is essential for smooth operation, reducing friction, and minimizing Z-banding on your prints. However, applying grease manually is often messy and results in an uneven coat.
This smart, syringe-style lubrication applicator is designed to solve that problem completely, making your 3D printer maintenance fast, clean, and professional.
🌟 Key Features
  • Smart Syringe Mechanism: The plunger design provides controlled pressure, pushing the lubricant deep into the grooves of the lead screw threads evenly.
  • Custom C-Clip Nozzle: The applicator tip features a specialized C-shaped clip that snaps securely onto the Z-axis rod. Just clip it on and slide it up and down—the grease spreads perfectly without dripping.
  • 100% Mess-Free: Say goodbye to spreading grease with your fingers or a brush. The lubricant stays neatly contained inside the barrel.
  • Perfect Match: Aesthetically optimized for Anycubic 3D printers (perfect for the Kobra X series), featuring a cleanly embossed logo and a distinct orange "X" mark on the plunger top.
📝 How to Use (4 Simple Steps)
  1. Remove the plunger: Pull the piston (the piece with the orange 'X') out of the main barrel.
  2. Load the grease: Snip the corner of your lubricant packet and squeeze the desired amount directly into the barrel chamber.
  3. Reassemble: Insert the plunger back into the barrel.
  4. Lubricate: Snap the C-clip nozzle onto your Z-axis lead screw. Slowly press the plunger while simultaneously sliding the tool up and down the length of the rod to distribute the grease evenly.
If you find this design helpful, please give it a Like and share your makes! Happy printing!
kobra
kobra x
anycubic
3d
3d print
tool
8.98MB
16.30MB
