2026-10-08 10:27:33
218
camera mounting clip
@morDinggg_5738140
This 3D-printed camera mounting clip is designed as a compact adapter for attaching an action camera or compatible accessory to a supporting base. The upper section features a three-prong mounting interface with a central hole for a fastening screw, allowing the camera angle to be adjusted and secured in place. The lower portion uses a snap-fit clip structure that can slide or lock into a matching mount, making installation and removal quick and convenient. Its reinforced shape provides good support while keeping the overall design lightweight and easy to carry. This mount is suitable for DIY camera rigs, helmets, tripods, handheld setups, or custom equipment where a small removable attachment point is needed. The simple construction also makes it practical for replacement parts or personalized 3D-printed camera projects.
camera
mounting
clip
compact
adapter
