2026-09-20 06:30:56
356
14
elephant shelf bracket
@alexs1499_2328520
A decorative elephant shelf bracket and wall lantern holder for 3D printing, perfect for home decor, small shelves, LED candles, and cozy wall lighting.
Add a unique touch to your wall with this decorative elephant shelf bracket, designed to work both as a functional shelf support and as a beautiful hanging lantern holder.
The elephant head gives the piece a sculptural and elegant look, while the upper bracket can be used to support a small shelf. The trunk area is designed to hold a hanging lantern, making it perfect for warm ambient lighting, bedroom decor, living rooms, kids’ rooms, cozy corners, or themed interiors.
This model combines practical use with decorative design: it is not just a lantern holder, but also a stylish wall bracket for a small shelf.
Features:
  • Decorative elephant wall bracket
  • Built-in hanging lantern holder
  • Can be used as a shelf support
  • Great for LED candles or small lightweight lanterns
  • Elegant wall decor for home interiors
  • Designed for FDM 3D printing
  • Looks great in white, ivory, beige, wood, stone, or marble-style filament
  • 4 Holes to mount the bracket
Important note:
For safety, use only LED candles or battery-powered lights. Do not use real flames near 3D printed plastic parts.
Load capacity depends on your filament, print settings, screw type, wall plugs, wall material, and shelf size. For best strength, use enough walls/perimeters, good infill, and proper screws for your wall.
Recommended use:
Perfect as a decorative shelf bracket, wall-mounted lantern holder, nursery decor, elephant-themed room decor, cozy lighting accessory, or a unique gift for animal lovers.
Print and installation tips:
Print with strong settings if you plan to use it as a shelf bracket. PETG is recommended for better durability, especially if the part may be exposed to heat or stress. PLA can work well for decorative use. Always mount it securely to the wall using suitable screws and anchors.
shelf
bracket
elephant
shelf bracket
home
diy
angle bracket
