The ultimate Spring Bonnie V2 (The Yellow Rabbit) wearable cosplay armor, fully optimized and ready for your 3D printer! Inspired by the iconic animatronic, this model has been accurately crafted and pre-split/cut into printable parts, allowing you to skip the tedious slicing process and jump straight into printing.
Perfect for movie-accurate or game-accurate FNaF cosplays.
📊 Material & Filament Estimation
- Total Filament Required: Approx. 2.5 kg or 2 kg (based on standard infill/wall settings).
Tip: Make sure to have 3 spools ready before starting this project to ensure consistent color and material quality across all parts!
- 3D Print Ready & Pre-Split: The entire model comes already cut into optimized, printer-friendly pieces that easily fit standard print beds.
- Wearable & Scaled: Designed and scaled for standard 1:1 cosplay armor. (Check dimensions in your slicer and adjust scale slightly if you need a custom tailored fit).
- Clean Geometry & Alignment: Features clean cuts to ensure strong structural joints and easy alignment during assembly/gluing.
- High Detail: Captures the perfect eerie, retro look of the Yellow Rabbit with smooth surfaces optimized for sanding and painting.
3D Printing Settings (Suggested)
- Infill: 5% - 15% (Gyroid suggested for durability and weight reduction) depends on the walls you put
- Walls/Perimeters: 2 to 5 for extra strength during post-processing (sanding/filling).
- Supports: Required for overhangs (Tree supports highly recommended for easy removal and cleaner surfaces).
- Material: PLA or PETG.
Note: Since this is a large-scale project, make sure to double-check the sizing of the pieces against your personal measurements before hitting print! the head is 31 cm wide in total
