2026-01-31 01:09:25
2.4k
198
gold chain
@maxong5321_4990662
Model Description Example:
✨ A Exquisite Gold Chain for Role-Playing ✨
A 3D-printable gold chain necklace designed for Cosplayers and prop enthusiasts, featuring rich details and outstanding texture. It achieves a realistic metallic sheen and substantial feel right off the print bed, requiring minimal post-processing. The model is optimized and highly recommended for PETG filament, balancing strength, flexibility, and surface quality to ensure durability during wear with smooth, comfortable edges.
🌟 Model Highlights:
  • Optimized for PETG: Robust structure with well-designed bridges and overhangs. PETG's excellent layer adhesion and flexibility ensure high print success rates and a more durable final product.
  • Realistic Texture: The natural gloss of PETG simulates metal effortlessly, while also being easy to paint for a luxurious finish.
  • Wearable Comfort: Smooth, rounded links prevent skin or clothing irritation.
  • Lightweight Design: Maintains strength while optimizing thickness to save material and reduce weight.
  • Print-in-Place: Designed for minimal assembly; simply remove supports and it's ready to wear.
🖨️ Recommended Print Settings (for PETG):
  • Material: PETG (Highly Recommended) | Colors: Gold, Bronze, or metallic filaments for best effect
  • Layer Height: 0.2mm (balanced) or 0.16mm (for finer detail)
  • Infill: 15%-20% (optimal strength-to-weight ratio)
  • Supports: Only needed for clasp connections (tree supports recommended for easy removal)
  • Print Speed: 40-60mm/s (slower speeds improve layer bonding for PETG)
  • Bed Temperature: 70-80°C | Nozzle Temperature: 245-255°C
  • Cooling Fan: 30%-50% recommended (prevents warping and enhances detail)
🎭 Use Cases:
  • Cosplay accessory (e.g., pirate, noble, warrior, rapper characters)
  • Stage performances & photo props
  • Statement piece for everyday fashion
  • Halloween & themed party costumes
📦 Included Files:
  • Main chain STL (split for common print bed sizes)
  • Clasp component STL
💎 Print and play — complete your character! If you like this design, please like, collect, or share it with fellow creators. We'd love to see your finished prints in the comments! Happy Printing!
cosplay
gold chain
necklace
accessory
prop
cosplay accessory
metallic
3D printed jewelry
role-playing
金链
项链
饰品
道具
cosplay配件
金属质感
可打印饰品
角色扮演
8.14MB
3.15MB
