2024-09-25 14:42:23
6.6k
881
sliding puzzle滑动拼图-s2
@mingGY_5877071
这是一套滑动拼图的3D打印模型,共有两个版本,分别是5x5和6x6的拼图格子。每个拼图块上都标有数字,玩家需要通过滑动拼图块,将数字还原到正确的顺序,完成拼图。这款拼图是非常适合学生的益智游戏,能够帮助他们锻炼逻辑思维和问题解决能力。
由于拼图块之间的缝隙较小,打印后可能会出现拼图块粘连的情况。为了获得最佳的打印效果,推荐使用PLA耗材,并以正常速度进行打印。如果打印完成后仍有粘连,建议使用一字螺丝刀沿着拼图块之间的缝隙轻轻划开。
This is a set of sliding puzzle 3D models, available in two versions: a 5x5 grid and a 6x6 grid. Each puzzle piece is numbered, and the goal is to slide the pieces into the correct numerical order to complete the puzzle. This sliding puzzle is an excellent educational game for students, helping to develop their logical thinking and problem-solving skills.
Due to the small gaps between the puzzle pieces, there may be some sticking after printing. To achieve the best results, I recommend using PLA filament and printing at normal speed. If the pieces still stick together after printing, you can gently separate them using a flat-head screwdriver along the gaps between the pieces.
puzzle
number
game
fun
toy
brain game
minggy
